traceroute
Use traceroute to determine the route packets take through a network to a destination.
Syntax
Command parameters for traceroute vary depending on the parameter input order. All syntax
possibilities are not listed. Use the CLI help to verify the syntax for available
parameters during command contextual input.
traceroute
WORD<0-256>
traceroute
WORD<0-256> <1-1176>
traceroute
WORD<0-256> <1-1176> mgmt <clip | oob | vlan>
traceroute
WORD<0-256> <1-1444>
traceroute WORD<0-256> grt
traceroute WORD<0-256> grt source
traceroute
WORD<0-256> -m <1-255>
traceroute
WORD<0-256> -m <1-255> mgmt <clip | oob | vlan>
traceroute
WORD<0-256> -p <0-65535>
traceroute
WORD<0-256> -p <0-65535> mgmt <clip | oob | vlan>
traceroute
WORD<0-256> -q <1-255>
traceroute
WORD<0-256> -q <1-255> mgmt <clip | oob | vlan>
traceroute
WORD<0-256> source WORD<1-256>
traceroute
WORD<0-256> -v
traceroute
WORD<0-256> vrf WORD<1-16>
traceroute
WORD<0-256> -w <1-255>
traceroute
WORD<0-256> -w <1-255> mgmt <clip | oob | vlan>
Command Parameters
- <1-1176>
- Specifies the wait time per probe.
The range depends on the hardware platform.
- <1-1444>
- Specifies the size of the probe
packet. The range depends on the hardware platform.
- grt
- Specifies traceroute is executed
in Global Router (GRT) context.
- -m <1-255>
- Specifies the is maximum
time-to-live (TTL).
- mgmt
- Run a traceroute test using a zero source IP address and route lookup in the main
table.
- mgmt clip
Segmented Management Instance. If you do not use the mgmt parameter, the
traceroute command uses the IP routing stack to initiate the traceroute
request.
- mgmt oob
- Run a traceroute test using a Segmented Management Instance. If you do not use
the mgmt parameter, the traceroute command uses the IP routing stack to initiate
the traceroute request.
- mgmt vlan
request.
- -p <1-65535>
- Specifies the base UDP port number.
If you send a traceroute command to a Segmented Management Interface or
interface address, you must use a UDP port range of 33434-33534.
- -q <1-255>
- Specifies the number of probes per
TTL.
- source WORD<1-256>
- Specifies the source IP address
for use in traceroutes.
- -v
- Specifies verbose mode (detailed
output).
- vrf WORD<1-16>
- Specifies the VRF instance by VRF
name.
- -w <1-255>
probe.
- WORD<0-256>
- Specifies the hostname, or IP
address.
Command Mode
Privileged EXEC
Usage Guidelines
The -v, source, and vrf
parameters are not available if the mgmt keyword is
specified.
The mgmt oob parameter is not
supported on 5320 Series.
